Discussion topic: WiFi cutting off
This message was authored by: Melissamcd
WiFi cutting off
WiFi keeps cutting on and off
Re: WiFi cutting off
@Melissamcd
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
