Discussion topic: WiFi connection
Message posted on 18 Nov 2025 07:48 PM
WiFi connection
Hi, I have ring door bell on my front door. It's getting weak WiFi. The WiFi hub is in the front room, and it's not in a cupboard. The front room is the only place I can have it, due to my set up. I have reset everything, but still no luck.
please help
Message posted on 18 Nov 2025 08:25 PM
Re: WiFi connection
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Message posted on 18 Nov 2025 09:24 PM
Re: WiFi connection
@Tonyrowe One of these will work if you do not wish or cannot relocate your sky Hub!
TL-WPA4220 KIT | AV600 Powerline Wi-Fi Kit | TP-Link United Kingdom
