Discussion topic: WiFi connection
This message was authored by: Vicky251
WiFi connection
The sky hub doesn't seem to be lighting up or have any signal
Re: WiFi connection
@Vicky251 About the hub lights as you do not say which you have!
Re: WiFi connection
@Vicky251 if your hub is not showing any lights and it is plugged into a working mains socket it is faulty and needs replacing. Sky hubs like most any router can be damaged by lightening storms if you have had one close by.this is quiteca common event.
