Discussion topic: Streaming twitching
This message was authored by: Ch4rl13
Streaming twitching
I'm noticing when I either use wifi or Bluetooth to my wireless speakers they are twitching and wondered if it's because they are on the same frequency and affecting each other? Can my wifi frequency be changed?
Re: Streaming twitching
@Ch4rl13 Depending on the hub you have you may be able to change the 2.4Ghz band but do stick to the recommended channels 3,6,11.
Avatar for Ch4rl13
Thank you, I will try this.
