Discussion topic: WiFi connection
Message posted on 18 May 2025 09:22 PM
WiFi connection
Every night between 2100 and 2130 the WiFi seems to drop out or loose connection completely. I check the service using the app each time and it always states no problem or issues found.
Message posted on 19 May 2025 07:17 AM
Re: WiFi connection
@HHardie unless the leds on your Sky hub changes at the sametime your issue is likely to be due to the WiFi signal from the hub to your device suffering from interference..in general interference does increase in the evening as your neighbours' are all usingbtheir networks but if the signal drops repeatedly at a fixed time the source is likely to be a device in your home common causes include a microwave cooker with a slight radiation leak but there are many others check if something is switching on or off when you get the issue.
