Discussion topic: Connection problems
This message was authored by: Gosia4
Connection problems
I have sky fibre but since I have it changed I can't connect to Netflix and have to put password every time and even after that it's still connection issues
Re: Connection problems
@Gosia4 changing the broadband router should not mean the Netflix app requires you to sign in to watch each tome so something else is going on. The broadband change can mean the device you are using needs to connect to the new wifi but should not affect any apps once the device is networked
