Discussion topic: WiFi connection
This message was authored by: Hannah1980
WiFi connection
I keep losing connection. It keeps dropping in and out.
Re: WiFi connection
@Hannah1980
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
