1
This discussion topic has been answered Discussion topic: WiFi but no internet
This message was authored by: curlywurly99
Help! I'm pretty tech savvy as I run an e-learning company. I've got WiFi connection but no internet. I've tried resetting the router. I've used your app and it checks out okay. I've turned my devices off and on. All lights are green on the router except voice which is orange. Why is there no internet. I'm off to work now. Can you give me some things to try when I get home?
Re: WiFi but no internet
@curlywurly99
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
@curlywurly99
