1
This discussion topic has been answered Discussion topic: No internet connection
This message was authored by: Magi4
We have  no internet , started having problems on 23rd May , internet would come back then go off again . We have followed all instructions that you provide and nothing works, no internet at all now, red light still on . Please help!
Re: No internet connection
@Magi4
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
@Magi4
