Discussion topic: WiFi broadband not working
Message posted on 15 Feb 2025 03:18 PM
My broadband and WiFi is not working run tests and it says no issues but there was a nothing works what am I paying for???? Sort it out asap
Message posted on 17 Feb 2025 08:23 AM
Re: WiFi broadband not working
@Melissar1
This is a customer helps customer forum and you aren’t contacting Sky Customer Services on here.
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
