Discussion topic: WiFi booster
Message posted on 05 May 2025 12:38 PM
WiFi booster
I've started a new contract new hub but my son doesn't get wifi in his room anymore. He use to with the old hub. You stated I would get WiFi all around my house!!
Message posted on 05 May 2025 12:44 PM
Re: WiFi booster
@Mrs+gail+stooker you are not talking to Sky by pisting in the forum. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
