Discussion topic: WiFi booster stops working at 2 30
Message posted on 06 Nov 2024 04:46 AM
My WiFi booster stops working at 2 30 am each day. Just the booster - I can connect to my normal router downstairs just fine, but the booster isn't working! It will be on for about 10 seconds to a couple of minutes, before turning back off. It turns back on normally by the time I wake up, 7am.
I have turned off eco mode on my sky Q. Additionally, often on the booster (while it is not working) all 3 lights are on, however it does not actually give me WiFi, my computer connected through ethernet doesn't work, and I can't get a signal from it on my phone. I don't know if they are related, but I have never encountered this outside of the hours in which the booster doesn't work.
Message posted on 06 Nov 2024 07:08 AM
Re: WiFi booster stops working at 2 30
@Snejosaurus do you have a Sky Q mini box in the same area? The reason for asking is that these also go into low power mode and lose their WiFi from 2.30 to 5.45am if in the default eco standby mode and each box has to be changed.separately.
