Discussion topic: intenet keeps dropping out although it says it running fine and i dont know why
This message was authored by: Aaronm89
Message posted on 06 Nov 2024 06:52 AM
Find out more
Message posted on 06 Nov 2024 07:04 AM
Re: intenet keeps dropping out although it says it running fine and i dont know why
@Aaronm89 the hub is connected to the line but as it has been running for over 2000 hours I would reboot the unit which may sort your issues. If the problems continue check whether both the Ethernet and WiFi conectiond. If both are affected try powering down the hub for at least 60 minutes to change the server connection as the issue can be at that end.
