Discussion topic: WiFi blackspot
Message posted on 07 Jun 2025 09:22 AM
WiFi blackspot
WiFi disconnects it part of the house
Message posted on 07 Jun 2025 09:31 AM
Re: WiFi blackspot
@Blackspot Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
