Discussion topic: WiFi Signal Booster
This message was authored by: 64Silverfox
WiFi Signal Booster
The Wifi signal strength dimishes throught house and even worse when just outside in garden. I install the following booster (2025 Newest WiFi Extender Booster, AC300 Mbps WiFi Booster Single Band, 4 Antennas Up to 5000 Sq.ft and 50 Devices, Internet Repeater - Ethernet Port,1-Click Setup,Access Point,Alexa Compatible) however signal strength is still not great.
Any recommendations for compatibale Wifi Signal booster to install?
Re: WiFi Signal Booster
@64Silverfox
Generally you are better off either using Sky boosters, or getting a full on 3rd party mesh system. Adding 3rd party boosters to the Sky hub can often just make things worse.
I am NOT a Sky Employee
