Discussion topic: WiFi down
Message posted on 17 Jun 2025 09:35 AM
WiFi down
Message posted on 17 Jun 2025 09:42 AM
Re: WiFi down
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 17 Jun 2025 09:46 AM
Re: WiFi down
Did you not read my message ? I said I've already used the trouble shooting/testing part of the app. I've already done these checks. Still not working. The message I get says there are no problems detected
Message posted on 17 Jun 2025 10:04 AM
Re: WiFi down
I did read your message but it wasn't clear what you had or had not done, so this is your only option if a reboot hasn't fixed it:
Message posted on 17 Jun 2025 10:08 AM
Re: WiFi down
I have turned it off and on again. And used the app to test the connection. That didn't work so now I'm asking you for help
Message posted on 17 Jun 2025 10:13 AM
Re: WiFi down
@Stupottyz wrote:I have turned it off and on again. And used the app to test the connection. That didn't work so now I'm asking you for help
@Stupottyz You need to call Sky then to report the fault, the forum is primarily a customer to customer support platform.
Message posted on 17 Jun 2025 10:16 AM
Re: WiFi down
As you can see I don't work for Sky so you will need to call them as I have suggested to you.
Message posted on 17 Jun 2025 10:19 AM
Re: WiFi down
What? I have called thrm the number saus to contact through the app. I have done this. To you. I don't understand how I've contacted someone who doesn't work for sky? Do you have the number I should call.
Message posted on 17 Jun 2025 10:27 AM
Re: WiFi down
This is a place where Sky customers help each other, it isn't a direct route to talk to Sky support.
150 is the free number to use from a phone that has a Sky mobile sim in it or Sky Talk phone otherwise under "Need more help ?" link at the bottom of the page on this link is the number to call Sky on:
Try saying nothing when spoken to by the bot.
