Discussion topic: WiFi Max hub
This message was authored by: Barb1954
WiFi Max hub
Is the Sky Max hub the same as the most upgraded ordinary hub?
I was sent the latest hub last week (black stand up) which I have connected, then I ordered the Sky wifi max hub which arrived yesterday (white) are these hubs the same? I don't want to go through the process of connecting if they both do the same thing?
This message was authored by: sea+dog
Re: WiFi Max hub
They are different the white comes with and extender pod.   If you use mini boxes in other rooms you will need to pair them with the Sky Q box and not through the old hub.
Re: WiFi Max hub
@Barb1954
The upright black model is the Sky Broadband Hub from 2019, and was built to the WiFi 5 standard.
The white Max Hub was released in 2023 and is WiFi 6.
Avatar for Barb1954
Re: WiFi Max hub
Thank you so much for taking the time to reply.
