Discussion topic: WiFi issues
Message posted on 22 Feb 2025 11:29 AM
WiFi issues
Since 21st Feb every couple of hours the WiFi disconnects and won't connect until it's switched off at the wall then back on again. According to system checker it is saying broadband and WiFi are fine but the clearly are not. Only 2 lights in my hub
Message posted on 22 Feb 2025 11:31 AM
Re: WiFi issues
@Carol108
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
Message posted on 22 Feb 2025 11:33 AM
Re: WiFi issues
Hi. I did all that and it keeps saying everything is working. I can only get it back if I switch off at the wall but then two hours later I have the same issue
