Discussion topic: WiFi Dropping Out
This message was authored by: ErolHassan
WiFi Dropping Out
The WiFi keeps dropping out. Not just occasionally, all the time. I have run online checks on the Sky APP and can't find any problems. It,s not good, I need to work from home. I need to cancel
Re: WiFi Dropping Out
@ErolHassan
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
To cancel Sky Broadband and Sky Talk the below link explains how to switch to an alternative provider or the various methods on cancelling completely.
https://www.sky.com/help/articles/cancel-sky-broadband
If you try to cancel whilst still in a minimum term deal you might have to pay an early termination charge (Sky will notify you if you do and how much they’ll charge).
NOTE: One Touch Switching only applies to broadband and Talk and not a TV subscription.
Return packaging for any equipment Sky expect back will be sent out to you near the end of the 14 day notice period. Remember to keep any proof of posting indefinitely.
