Discussion topic: Broadband out again
Message posted on 18 Nov 2025 07:50 PM
Broadband out again
An outage in Par cornwall started at around 7pm last night, came back around 12 today.
Gone again 6:30 this evening, after running tests the app says no known issues in the area, but can't detect my hub. Seems an unlikely coincidence were it to be a hardware fault my end, so assume it's another outage. Anyone else in the area to confirm?
Message posted on 18 Nov 2025 08:02 PM
Re: Broadband out again
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
