Discussion topic: Internet is not working or phone line or sky box
This message was authored by: anderson-goldup
nothing seems to be working
Re: Internet is not working or phone line or sky box
@anderson-goldup
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
