Discussion topic: WiFi Booster
Message posted on 14 Apr 2025 02:28 AM
WiFi Booster
WiFi Booster Needs a Better Connection to the Broadband
Message posted on 14 Apr 2025 07:16 AM
Re: WiFi Booster
@David1211 boosters need careful placement as thry need a decent connection tothe hub to actually work effectively so should be placed halfway between the hub and where you need the boost. If even then the boost is weak while it is possible to connect a second booster in a daisy chain arrangement consider using a differentvapproach as each booster jump halves the wifi speed so with two you can only get 25%. Technologies like powerline which use the mains wiring to carry data or a true WiFi mesh system while costing more are far better solutions.
