Discussion topic: Wi fi keeps cutting out, router keeps going blank
Message posted on 19 Nov 2025 10:21 AM
The wifi keeps cutting out because the router keeps cutting off
Message posted on 19 Nov 2025 11:00 AM
Re: Wi fi keeps cutting out, router keeps going blank
@Bob221
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
