Discussion topic: Wi fi issues
Message posted on 15 Jul 2025 10:35 AM
Wi fi issues
Message posted on 15 Jul 2025 11:04 AM
Re: Wi fi issues
@macbun When you upgraded to fibre 300 did you change router or is this the same router you had when you had fibre 150?
Message posted on 15 Jul 2025 11:21 AM
Re: Wi fi issues
Hello thanks for the reply.
I got a brand new router when I upgraded.
Message posted on 15 Jul 2025 11:37 AM
Re: Wi fi issues
@macbun Which router did you have before the upgrade from the link below.
Message posted on 15 Jul 2025 12:11 PM
Re: Wi fi issues
Hello, I think it was the broadband hub.
I did have sky Q at the same time, but when I upgraded the broadband I ditched sky tv completely
Message posted on 15 Jul 2025 01:07 PM
Re: Wi fi issues
@macbun Did the link @Highlinder supplied not help to see which one!
Message posted on 15 Jul 2025 01:10 PM
Re: Wi fi issues
Hello.
please see my previous answer
Message posted on 15 Jul 2025 01:12 PM
Re: Wi fi issues
@macbun Got it... No problem!
Message posted on 15 Jul 2025 01:29 PM
Re: Wi fi issues
@macbun Do you still have the broadband hub or did you send it back? As that hub would have done the job just as well.
Message posted on 15 Jul 2025 02:10 PM
Re: Wi fi issues
They asked for it back, and I sent it back.
They provided a brand new one (white in colour)
Message posted on 15 Jul 2025 02:16 PM
Re: Wi fi issues
@macbun I would have kept the black one for a bit to see if the new white one worked okay and then when it did not work as well called them so you could send the white one back and kept using the black one.
