Discussion topic: No wifi
This message was authored by: DrTim
No wifi
I have just rejoined Sky for broadband and Talk. I have wired the router close to BT entry box as suggested but this is too far away from main computerto use an ethernet cable . I used to have a box (?booster) at the entry point and the router in the office so I could plug in the ethernet cable direct to the router. The computer does not have a wifi option. Any ideas?
Re: No wifi
@DrTim  You can use a longer ethernet cable from the Openreach modem to the router if you like. The short cable is just the standard length that is sent out.
