Discussion topic: Wi fi going off
Message posted on 04 Mar 2025 03:57 PM
Wi fi going off
When I go upstairs the wi fi drops off to no wi fi
Message posted on 04 Mar 2025 04:19 PM
Re: Wi fi going off
@Joe169 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
