3
This discussion topic has been answered Discussion topic: I have ordered a sky box but have just thought do i need wifi or broadband to use it
This message was authored by: ShadeypuSS1977
I have just ordered a sky box and I thought do I need wifi or broadband to use it,  if so how do I go about getting it
Re: I have ordered a sky box but have just thought do i need wifi or broadband to use it
@ShadeypuSS1977 short answer is yes both Sky Q and Sky Stream require a broadband connection the work. Sky Q will allow domestic viewing of thecsatellite channels but on demand and apps wont work without an internet connection. Sky Stream cannot do anything without a decent internet connection.
You dont need to buy the broadband from Sky as the TV boxes work with most nesrly any broadband provider. If uou dont have any connection you need to shop around to see what is available at your address. Sites like USwitch are helpful.
Avatar for ShadeypuSS1977
Can I get wifi through sky then??
@ShadeypuSS1977 that will depend on whether you have or can have an Openreach line installed st your address see https://www.sky.com/broadband/buy
