Discussion topic: Wi-Fi
Message posted on 22 Jul 2026 02:21 PM
Wi-Fi
I'm looking at the block box now and it is showing green orange green orange so the Internet is not working. Why
Message posted on 22 Jul 2026 02:28 PM
Re: Wi-Fi
@Vanessa181
There have been issues in parts of Yorkshire since late morning.
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
