Discussion topic: Broadband leeds ls13
This message was authored by: Janp1963
Lost connection to Internet service checker says no iss
Re: Broadband leeds ls13
@Janp1963  You may need toi check again as it can take a couple of attempts for the checker to update
If there isn't try running the line test here:
Avatar for Janp1963
Have run tests a few times and they say all is fine, but still connected no internet
This message was authored by: DaveF4
Same here in Batley. Says no issues so the sky checker is useless. Checked it 5 times and restarted.
This message was authored by: Laura495
WiFi is not working
WiFi has stopped working . All green lights on black box . All green lights and Ethernet light on box on wall flashing and 1 green light on white box and 1 red light on white box los
Re: WiFi is not working
@Laura495
Where abouts are you, anywhere n Yorkshire ?
Yes Leeds
