Discussion topic: Wi-Fi weak security
Message posted on 08 Mar 2025 01:05 PM
Wi-Fi weak security
I have an iPhone XR and against the Wi-Fi it says weak security WEP is not considered secure....information states configure router to use WPA2 (AES) or WPA3 security type....what do I need to do?
Message posted on 08 Mar 2025 01:10 PM - last edited: 08 Mar 2025 01:20 PM
Re: Wi-Fi weak security
You need to login to your broadband hub and change the security setting:
https://www.sky.com/help/articles/access-your-sky-broadband-hub-settings
Message posted on 08 Mar 2025 02:58 PM
By default any current Sky Hub model will be using either WPA2-PSK or WPA3-T. Apple devices appear to misdiagnose this issue.
