Discussion topic: Wi-Fi problem
This message was authored by: Normabernard
Wi-Fi problem
Good morning. I've got no Wi-Fi since yesterday my TV don't work and the Wi-Fi on my phone and other device doesn't work because my Wi-Fi system is down
This message was authored by: Eric2401
Re: Wi-Fi problem
Are u still having problems cause mine is the same
Re: Wi-Fi problem
@Normabernard & @Eric2401 unfortunstely with over 5 million customers it is inevitable that a small % of Sky Broadband customers will be offline at any time. The online service checker in the My Sky app which works over a mobile vonnection takes up to an hour to pick up a lost connection but oonce it does it checks if Sky arexaware of an issue affecting your line which is already being dealt with or its a new issue in which case it can report the problem and book an engineer to fix it. Alternstively call Sky when their lines open but the process is essentially the dame.
This message was authored by: Neats04
Re: Wi-Fi problem
Mine is the same. Switched it all of and on and still nothing. When I check my connection on the sky app it says we can't check your line right now try later. Great so they can't even help on there. I suppose it will be a phone call to them (although to speak to a human is like pulling teeth) to try and help the situation or to be able to check the line!! So annoying
