Discussion topic: Wi-Fi off again today.
This message was authored by: Ralphdog12
Wi-Fi off today sgain
Avatar for Ralphdog12
Re: Wi-Fi off again today.
Why is this keep happening
@Ralphdog12
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
@Ralphdog12 Also best if you stick it all on one post rather than multiples if possible!
@Ralphdog12
The post spotted by @JimM1 on an old thread you added to yesterday has been removed as you've created your own thread today and it prevents duplication of replies.
