Discussion topic: No broadband
Message posted on 09 Dec 2025 11:34 AM
No broadband
I have no broadband connection
I have a green light a flashing orange light then a green light
Message posted on 09 Dec 2025 11:37 AM
Re: No broadband
@Janiceyoung First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Re: No broadband
@Janiceyoung
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
