Discussion topic: Wi-Fi issues
This message was authored by: Dc1995
Wi-Fi issues
Wi-Fi continue to lose connection on a regular basis however a hard reset often seems to fix it. I therefore think it is an issue with the router and not connection. Can you send me a replacement router?  Thanks
Re: Wi-Fi issues
@Dc1995 You will need to call sky, expect them to want to run some diagnostics against your hub. Number is below in the need more help.
https://www.sky.com/help/home
