Discussion topic: Internet issues
Message posted on 06 Jun 2025 07:52 PM
Internet issues
Our internet has been off since before we went to work and for the last three hours. We cannot use Sky Glass at all.
Message posted on 06 Jun 2025 07:53 PM
Re: Internet issues
@selinabeana
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
