Discussion topic: Wi-Fi issue
This message was authored by: Siobhan2411
Wi-Fi issue
My Wi-Fi is not working correctly. The lights are orange on the modem and I'm having to use data to get a connection
Re: Wi-Fi issue
@Siobhan2411
If you are having broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
▪️I AM NOT A SKY EMPLOYEE ▪️
