Discussion topic: Wi-Fi down
This message was authored by: Wifi18
Wi-Fi down
Hi my WiFi isn't working can you help
Re: Wi-Fi down
@Wifi18
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it ~ it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
