Discussion topic: No internet again
Message posted on 08 Nov 2025 05:23 PM
No internet again
Hi, I lost connection early afternoon Thursday and had no internet connection until early this morning, just before a tech arrived. They came and checked the services and all ok. Although others in the area had reported similar issues > hub just goes green but openreach connection appears fine. Literally just gone off again. So got no TV or internet again on the weekend. Please can someone sort this ?
Tim
Message posted on 08 Nov 2025 06:16 PM
Re: No internet again
We can't. You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it ~ it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
