Discussion topic: Wi-Fi down
Message posted on 04 Sep 2025 12:47 AM
Wi-Fi down
Wi-Fi not working. Showing as working on app but both tv showing no connection and phone not connecting
Message posted on 04 Sep 2025 12:51 AM
Re: Wi-Fi down
Mine has done the same is it slowly flashing green too?
Message posted on 04 Sep 2025 01:07 AM
Re: Wi-Fi down
I went into the sky app on pc and came across option to restart hub (after checking cables prompt), 2 mins later and the correct lights are on on the hub. I did have to manually log back in on my devices though.
Message posted on 04 Sep 2025 04:38 AM
Re: Wi-Fi down
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If your broadband isn’t working after 7am use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
