Discussion topic: Light are yellow
Message posted on 04 Sep 2025 02:36 AM
Light are yellow
My lights on my box are yellow but when I keep running my service checker it says that there is no issues even though nothing will connect to the internet
Message posted on 04 Sep 2025 04:40 AM
Re: Light are yellow
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If your broadband isn’t working after 7am use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
