Discussion topic: Wifi dropping
Message posted on 03 Sep 2025 10:20 PM
Wifi dropping
Sky wifi keeps dropping out with the orange light on wifi and voice. Checked service checker on sky website and tells me no issues and all connected when it literally is glowing orange.
Anyone else having issues ?
Unplugged and restarted it threw times now
Message posted on 04 Sep 2025 04:08 AM
Re: Wifi dropping
I've moved your post to the Broadband board.
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
