Discussion topic: Wi-Fi calling stopped working
Message posted on 08 Aug 2026 10:47 PM
My WiFi calling has stopped working all of a sudden. I've toggled on and off but no joy. I've two sims in my phone and the WiFi calling on the other network still works fine so nothing wrong with the phone itself
Message posted on 09 Aug 2026 08:26 AM
Re: Wi-Fi calling stopped working
@THF213 the fact WiFi calling works with one sim shows that there is not an issue with your Broadband either. The availability of WiFi calling is controlled by you mobile carrier and can be flaky especially with virtual carriers.
Message posted on 09 Aug 2026 08:39 AM
@THF213 wrote:My WiFi calling has stopped working all of a sudden. I've toggled on and off but no joy. I've two sims in my phone and the WiFi calling on the other network still works fine so nothing wrong with the phone itself
I've just checked mine and although I'm fairly certain I had it turned on, it was actually off. Mine has a 2 sim option but wifi calling is independent of each sim, so make sure that both are set to wifi calling.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Message posted on 16 Aug 2026 11:36 PM
I checked and it was definitely on. I've seen a few threads for this issue now so must be a common enough issue
Message posted on 17 Aug 2026 06:57 AM
@THF213 wrote:I checked and it was definitely on. I've seen a few threads for this issue now so must be a common enough issue
As it happens I turned mine off the first time I got a call through wifi, it was terrible and instantly cleared when I turned off wifi 😞
Technology eh...
Not a Sky employee
