4
This discussion topic has been answered Discussion topic: Open reach full fibre install soon
This message was authored by: Destinys+Child
Hopefully someone can help .....I'm currently in the process of upgrading to full fibre and waiting on initial inspection & install of open reach  ONT
What is the maximum length of RJ45 Ethernet cable provided on initial install ??? As the new position where the ONT will be positioned  will Require about 25/30 metres of cable along skirting board & around door frame to connect to Router . Will I have to purchase this cable separately before installation? Or is it it something that will be provided on instal day ??
Thank you in advance 🙂
Re: Open reach full fibre install soon
@Destinys+Child
When Openreach did mine the supplied cable was quite short which for me is fine as the hub is right next to the ONT, you will have to get the cable yourself from somewhere if you need a fairly long one.
@Destinys+Child
The only lead provided is a standard short one.
You'd need to source and install the longer length yourself (or pay someone) : it's not something Sky or Openreach will do.
@Destinys+Child
Avatar for Destinys+Child
Level 2 icon
Thx Guys 👍 I'll make a purchase before installation THANK YOU
This message was authored by: Me134
I would be wary of tacking the cable in anywhere until the ONT position is confirmed and in place, the ONT itself will require a nearby power socket.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
