Discussion topic: Why is myvwifi not working?
This message was authored by: Joball25
I dint have WiFi.
I have cancelled my tv package but not my WiFi so why has this stopped?
This is soooooo inconvenient @
Re: Why is myvwifi not working?
@Joball25
Probably a coincidence. If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
▪️I AM NOT A SKY EMPLOYEE ▪️
