Discussion topic: Wi fi
This message was authored by: Clair79
Wi fi
Wi fi not working again!!!!!!
Re: Wi fi
@Clair79
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it hasn't returned by 0700 use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
▪️I AM NOT A SKY EMPLOYEE ▪️
