Discussion topic: Broadband wifi going on and off for the past 4 days
Message posted on 20 Apr 2025 11:48 PM
Hi, our home broadband is going on and off for the past 4 days, run the test and it says everything is ok? The broadband router when this happens flashes orange and red then goes to green when comes back on. Why is this happening please when it says the tests run are fine
Message posted on 21 Apr 2025 12:19 AM
Re: Broadband wifi going on and off for the past 4 days
@Oli5
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
