Discussion topic: Who can I call
This message was authored by: Suzziep
Who can I call
Internet is not working. Checks are saying everything is fine. It isn't.
Re: Who can I call
@Suzziep
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
This message was authored by: Ren96
Re: Who can I call
There's apparently several outages. My internet has been down since this morning .
i get the message of there's an outage u. Your area this should be fixed in a couple of days when I do the checks
Re: Who can I call
@Ren96
The same as with your own thread the service level agreement in the UK between ISP’s and Openreach for fixing a fault is 2 WORKING DAYS which is why that time period is usually mentioned.
