Discussion topic: Wfi/broadband drop out
Message posted on 26 Apr 2024 02:22 PM
Message posted on 26 Apr 2024 07:07 PM
							Re: Wfi/broadband drop out
@dalewood Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Message posted on 26 Apr 2024 08:43 PM
We have the same issue we run the test as said in here and all comes back OK we have a firestick and do a speed test on there and it comes back at 2.54 mbps it is also the same on a external speed test app . Restarting the hub doesn't work as well as my sky box's loose connection as well
Message posted on 03 Jul 2024 01:09 PM
In morning No wfi and yet in settings it shows wfi and ticked with two/ three bars . This tends to happen throughout day wfi comes and goes. Using lap top then no wfi same with tv with mini boxes only been happening for four weeks . Open reach did not cure this issue
