Discussion topic: Webpages don’t load when using broadband
Message posted on 17 Jan 2024 05:44 PM
When I try to load webpages on my mobile I have to switch over to data 90% of the time as the page either only loads half way, or just doesn't load at all. Similar thing happens with email, but I notice it happening on webpages a lot more often. Tried to turn the broadband off and on, checked area connection etc but this has been happening for 2 years now and nothing has seemed to work
Message posted on 18 Jan 2024 10:46 AM
Re: Webpages don’t load when using broadband
Hi @mia6
Please post your router stats
Message posted on 18 Jan 2024 11:04 AM
Message posted on 18 Jan 2024 11:05 AM
Hi @mia6
That isnt quite what we are looking for, please follow the instructions till the end (Its the show statistics button at the bottom of that page)
Message posted on 18 Jan 2024 11:07 AM
Ah sorry - I didn't even see the statistics bit at the bottom hopefully this is right?
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 9343671 24018050 0 0 0 35:12:38 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 47113274 2408426 0 0 0 2646:39:45 WLAN (5 GHz) Up 1185154203 480555733 0 2 2 2646:39:39
Message posted on 18 Jan 2024 11:30 AM
For starters your hub has been up for 2000+ hours so i would give it a reboot so it can reconnect to the best wireless channel
Message posted on 18 Jan 2024 11:33 AM
okay thanks, just rebooting now.
I've previously rebooted and it hasn't changed anything - if this doesn't work do you know what my next step could be ?
Message posted on 18 Jan 2024 11:35 AM
It can often be down to a number of things such as
- Using wireless boosters/extenders, especially 3rd party ones
- Interference from neighbouring WiFi
- Too many devices using WiFi rather than ethernet
- Interference from an appliance within your home
Message posted on 18 Jan 2024 11:36 AM
Thanks for your help!
