Discussion topic: Weak WiFi
This message was authored by: Tristan9
Weak WiFi
We've just moved into a new property and moved our sky broadband with us. The internet is so weak that we cannot get any signal upstairs in the house. Also when stresmong through the sky tv box it keeps buffering even though the sky internet box is not far away from the tv. Is there anything the can be done to be able to use the WiFi all round the house otherwise I'll be forced to look at other providers. Thank you
Re: Weak WiFi
@Tristan9
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
